heard a high pitched noise just before reverse went out
2000 CHEVROLET
96,000 MILES • V8 • 4WD
RICKPARKS
Was stuck in snow on a downward angle and had to back out. After awhile wheels stopped spinning and reverse gear did not engage. Checked fluid level was okay. I have no reverse. Is this something I can fix myself? Need to add that I heard high pitched sound from right front wheel before reverse was lost.
Dec 14, 2016 at 12:09 AM
KOOLCADDY6
  • 60 POSTS
Possible that your reverse gear or clutch has failed. did you notice if your fluid was black or burnt or maybe some metallic in it?
Dec 14, 2016 at 1:13 AM
RICKPARKS
Fluid was fine. Not black or metallic.
Jan 2, 2017 at 11:39 PM
DOCFIXIT
  • 18,828 POSTS
Internal damage has occurred you will need to take to a certified trans repair facility
Jan 3, 2017 at 2:46 AM
