Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
RAV4
Drivetrain
Transmission
Reverse
Reverse not working?
2002 TOYOTA RAV4
100,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
PACIFICISLANDER
MEMBER
Need to know out of the 5 solenoids which solenoid involves the reverse gear.
Apr 15, 2021 at 8:34 PM
Experienced Mechanic
Good morning,
None of the solenoids control reverse operation. This is mechanical and there is no electronic control for engagement.
I attached a chart below for no reverse for you. It is an internal failure in the transmission itself.
I attached a picture of the location of the solenoids in the valve body for you as well but again, none of them control reverse operation.
Images (Click to enlarge)
Apr 15, 2021 at 9:16 PM
PACIFICISLANDER
MEMBER
Roy,
Sorry my bad its a 2.0 l not a 2.4 l is it the same transmission liter.
Apr 15, 2021 at 11:52 PM
It is the same.
Apr 16, 2021 at 1:24 AM
PACIFICISLANDER
MEMBER
Might as well buy second hand transmission, but I need to know what's interchangeable. can you assist on the year?
Apr 24, 2021 at 5:49 AM
I attached a website for getting a transmission. Enter your information and zip code and it will list all the yards with transmissions for you.
WWW.car-part.com
I attached the procedure for you below.
Apr 24, 2021 at 6:45 AM
PACIFICISLANDER
MEMBER
Thank you very much Roy sure appreciated. Stay safe and family.
Apr 25, 2021 at 8:06 AM
You are welcome.
Always glad to help.
Apr 25, 2021 at 10:48 AM
Add image or video
Ask a new question
Engine won't start
Engine has low power
