Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Mazda
b4000
Drivetrain
Transmission
Reverse
Will not go into reverse?
1996 MAZDA B4000
200,000 MILES • V6 • 4WD • AUTOMATIC
YOURAVERAGEMAN
MEMBER
1 POST
My vehicle listed above will not go into reverse, but it runs in drive just no reverse. I'm confused and could really use some help.
Oct 18, 2024 at 8:07 AM
Experienced Mechanic
Have you checked to see if the fluid is burnt? If so the reverse clutches/band is burnt up and the transmission needs to be rebuilt.
This guide can help:
https://www.2carpros.com/articles/how-to-check-and-add-transmission-fluid
If the transmission has been rebuilt, I would install rebuilt valve body that has all of the shift solenoids. Check out the images (below). Please let us know what happens.
Image (Click to enlarge)
Oct 19, 2024 at 2:19 AM
YOURAVERAGEMAN
MEMBER
1 POST
Thank you very much, I appreciate you.
Oct 20, 2024 at 2:20 AM
You are welcome, let us know how it goes.
Oct 20, 2024 at 3:52 AM
Add image or video
Ask a new question
Engine won't start
Engine idles rough
