NO REVERSE
150,000 MILES • 1.7L • 4 CYL • FWD
V5317985
Hi, my name is Vitaliy, and i own a Honda Civic 2003 EX. I have a problem with my reverse ... well more like i dont have reverse at all, for a about a year now due to the fact that I got a price quote on transmission replacement or fix and it was just little more the the price of the whole car.. but now that I have been driving for almost a year without reverse make me wonder if it could be something else other than transmission.
English is my 2nd language .. sorry for bad spellcheck...
more detail ..
when i drive car works perfectly without any weird sound or other problems.. but if i switch to reverse the cars make the grinding or just unpleasant noise and it doesnt reverse..
CODES that i got were P0420, P0131 .. i did order O2 sensor that im going to replace this weekends. other than that .... I DO NOT have an engine light on. and yes the light work when i start the car. cant really think of anything else useful to tell you. but i guess my question is .. could something else other then transmission cause my reverse problem and how likely>?
Feb 2, 2016 at 12:38 AM
HMAC300
  • 48,601 POSTS
the 420 code is catalytic converter bad as well so that will need replacement. the trans probably has a clutch pak shot so it won't work until it's rebuilt or go to a junk yard and get one from there for your car
Feb 2, 2016 at 12:56 AM
V5317985
Thanks for a fast reply. So I see in other words I'm f**ked ... can't really tell if it's even worth the $ to fix or just trade it in.
Feb 2, 2016 at 1:04 AM
HMAC300
  • 48,601 POSTS
check with a junkyard on another trans that will be cheapest option of course you will have to install it.
Feb 2, 2016 at 1:35 AM
