Blows only cold air, both coolant hoses are not warm. Recently replaced the HVAC control valve because there was a crack on the output side. Is it possible that the control valve is stuck close? I verified there is vacuum going to the valve. Front heater works fine, all settings. Coolant level is good. Front heater works fine, all settings. Coolant is topped off.
Dec 26, 2017 at 10:24 AM
