No radio or climate controls?
185,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
SCOTTD1970
The radio has no power. The fan on the climate controls are not working. No heat or A/C comes out. I replaced fuses and the relay in the fuse box inside vehicle. Battery was dead. Replaced with new one. Not the T95 battery.
Jan 17, 2023 at 5:51 AM
  • 110,248 POSTS
I'm looking through wiring schematics and the only thing I see in common between the two circuits may be the ground location. However, I need to know if your vehicle has a standard radio or one with a remote amp.
Also, let me know what fuses have been replaced, if anything on either of the two components works, if I am correct and the problem is the blower motor that isn't working, and if there are any other electrical components not working.
One other thought. When you checked the fuses and replaced them, did you confirm there is power to and from the fuse? If not, please confirm that for me.
Jan 17, 2023 at 11:17 AM
SCOTTD1970
Okay. I replaced both the radio and the amp fuses. No luck. I replaced the relay for blower motor. No luck. I haven’t replaced the blower resistor yet.
Jan 17, 2023 at 11:54 AM
  • 110,248 POSTS
Was power present at both fuse locations? Also, before you replace the resister, check the orange wire at the resister to power when you request the blower on high, key on.
There are BCM fuses and an HVAC relay that may be an issue as well. See the pics below.
Let me know what you find.
Jan 17, 2023 at 12:28 PM
SCOTTD1970
Got it. I will get back on it about 11a CST. Then give you an update. Thanks
Jan 17, 2023 at 8:45 PM
