no pulse
2002 HONDA STREAM
140,000 MILES • 1.8L • 4 CYL • 2WD
MOREBLESSING MASANGO
I put the ignition key on and the number three coil pack experienced a short i checked the pulse is not there. i put the diagnose tool it gives me the dtc code: p1607.
Aug 3, 2016 at 8:56 PM
Enter reply...
Aug 3, 2016 at 8:58 PM
RIVERMIKERAT
  • 6,110 POSTS
Our reference says that the P1607 code means there is a problem with the PCM. Have you jump started the engine recently? Check the connections to the PCM and check the grounds.
Aug 4, 2016 at 3:33 AM
