Engine runs cold
1998 FORD F-150
135,000 MILES • 4.2L • V6 • 2WD • AUTOMATIC
FUBARGRN
My radiator is slowly leaking from the passenger front corner (near petcock), and the upper hose never really got tight, so I replaced the thermostat and pressure cap. Now, I cannot get the truck to warm up, or blow hot air through the HVAC system. Temp gauge never gets higher than a few ticks above cold. Upper hose flows water when taken off, so water pump is pumping.
Jan 12, 2016 at 4:05 AM
HMAC300
  • 48,601 POSTS
pull hvac fuse inside truck it may be the blend door actuator needs to be reset or it's bad.
Jan 12, 2016 at 4:31 AM
FUBARGRN
Blend door actuator would cause the truck temp gauge to never really rise?
Jan 12, 2016 at 4:40 AM
HMAC300
  • 48,601 POSTS
no not that but it can be a problem for no heat. check your coolant level as you may have air in system and not be full. what temp was tstat if it wasn't 195 then it was wrong temp and that may be the real problem. make sure both hoses leading to heater are hot as well. the temp gauge may be wrong as well. even if it worked right before.
Jan 12, 2016 at 5:03 AM
FUBARGRN
Blend door is working, coolant levels are normal, No hoses are getting hot. standard 195 degree thermostat was replaced yesterday. I can squeeze upper hose with pressure cap off, and can see coolant flowing into the de-gas bottle. Water pump is pumping. I removed upper hose when engine was "cool" and water flowed like a flood when I started it up.
Jan 12, 2016 at 5:08 AM
HMAC300
  • 48,601 POSTS
after truck is warm with engine off and fans not able to start, feel radiator in different spots it should be warm all over if not the radiator may be bad and with outside temp being cooler weather may be the cause. I can't think of anything that will cause this especially with a new rad cap. unless it's the wrong cap
Jan 12, 2016 at 5:23 AM
BOBRLANE
Vehicle throws out no heat after driving it two to four miles the oil light comes on and temperature gauge goes up past H.
After pulling over and turning ignition off for three or four minutes the temperature gauge goes to normal range oil light goes off and it throws out good heat.
Had it into a mechanic and they replaced a sensor under the intake and this did not solve the problem.
Please help. thank you .
Jul 30, 2020 at 3:23 AM (Merged)
SCGRANTURISMO
  • 4,897 POSTS
I would recommend doing a compression test on your vehicle. Also I would check the engine oil to see if it looks like coffee with creamer in it. It sounds like you might have a blown head gasket. Here are a couple of links below explaining a couple of different test you can do to check to see if your vehicle does have a blown head gasket:
Also here is another one:
https://www.2carpros.com/articles/coolantantifreeze-in-the-engine-oil
Please go through these guides and get back to us with what you find out.
Thanks,
Alex
2CarPros
KOMETLUVER
Truck starts cold, runs smooth. It seems as soon as something tell it that it has come up to temp, RPM increases drasticly (2000-3000)RPM. I have replaced the MAF, IAC and the TPS. Only code I get is a low temp sensor reads low, then high after issue starts. Once issue begins if you place truck in drive it will die, will only start with throttle floored and will not stay running.Check engine light is on. No apparent vacuum leaks. Let sit for 24 hrs and starts and takes load fine untill warm-up. Seems like a mechanicaly induced vacuum leak at running temp?? HELP
Thank You,
Randy
  • 110,244 POSTS
Randy, replace the ambient temp sensor. It sounds like it is causing the vehicle to get too much fuel when it is hot.
KOMETLUVER
Thank You, Will try ASAP!
Randy
TOM EDWARDS
Engine Performance problem
1995 Ford F150 V8 Two Wheel Drive Automatic
when i first start it and the motor is cold it runs ruff if you let it worm up a little it runs ok
Clean out the idle air control valve and see what happens
