No power when it warms up
16,000 MILES • 4.3L • 6 CYL • 4WD • AUTOMATIC
DAVFORYOU
My blazer has no power when you step on the gas after it warms up an the voltage needle is going up an down not charging the battery when you step on the gas
Feb 6, 2016 at 8:17 AM
  • 55,732 POSTS
This sounds like it can be two separate problems, the low power sounds like the cat can be plugged while the voltage meter problem sounds like the alternator is going out, here are links to check both
https://www.2carpros.com/articles/engine-has-low-power-output
and
Please let us know what you find so it will helps others
Mar 7, 2016 at 2:55 AM
