No power whatsoever
157,000 MILES • 3.5L • 5 CYL • 4WD • AUTOMATIC
SANTIABEYTA1266
  • 15 POSTS
I have no power when turning the key after doing an alternator change and also a big 3 upgrade.
Sep 29, 2019 at 10:56 AM
  • 110,248 POSTS
Welcome to 2CarPros.
Exactly what is a big 3 upgrade? Also, does anything work such as the head lamps?
Sep 29, 2019 at 11:35 AM
SANTIABEYTA1266
  • 15 POSTS
The big 3 upgrade is upgrading the 3 main charging wires. And there is absolutely no power.
Sep 29, 2019 at 12:44 PM
  • 110,248 POSTS
Welcome back:
If you have nothing, either you lost power to the under hood fuse panel or ground. Something should work even if the alternator was replaced. See pic 1 and 2. Since nothing is working, this is where I would start.
Sep 29, 2019 at 1:04 PM
SANTIABEYTA1266
  • 15 POSTS
Thank you so much man!!! I think you narrowed down the problem good enough to solve it. Thanks again!
Sep 29, 2019 at 1:48 PM
  • 110,248 POSTS
Welcome back:
You are very welcome. Let me know what you find.
Sep 30, 2019 at 12:02 PM
SANTIABEYTA1266
  • 15 POSTS
It was the wire you were talking about. Can I ask one more question?
Sep 30, 2019 at 12:04 PM
  • 110,248 POSTS
Welcome back:
I hate to ask this, but we are trying to keep the threads specific to one topic. If the question is related, I would be happy to continue on this thread. If it is something different, would you please start a new thread. I hate asking that, but it becomes more beneficial to others when it is done that way. I will watch for a new post for you if it is something different.
I hope you understand.
Sep 30, 2019 at 12:40 PM
SANTIABEYTA1266
  • 15 POSTS
No sir it is related. I was just wondering how to tell if the megafuse is bad?
Sep 30, 2019 at 1:55 PM
  • 110,248 POSTS
Welcome back:
What to do is check for power at both ends of the fuse. If there is power only at one side, remove the fuse and check it for continuity. Here is a link that explains how to check one:
Here are a few links you may find helpful:
Let me know if that helps or if you have other questions.
Oct 1, 2019 at 10:10 AM
SANTIABEYTA1266
  • 15 POSTS
Thanks again sir.
Oct 1, 2019 at 10:39 AM
  • 110,248 POSTS
You are very welcome. Please let me know what you find or if you have any questions, feel free to ask.
Oct 1, 2019 at 10:45 AM
SANTIABEYTA1266
  • 15 POSTS
My megafuse was out. Replacing it solved the problem.
Oct 1, 2019 at 11:34 AM
  • 110,248 POSTS
Welcome back:
Great! Glad to hear you got it fixed. It took a lot to blow that one. LOL
Let us know if you need help in the future.
Oct 1, 2019 at 12:54 PM
SANTIABEYTA1266
  • 15 POSTS
Vehicle has power but will not crank. This problem started with me and a few friends trying to replace my alternator. In the process of doing so, we ended up having to take the fuse box and battery off which was fairly easy and non troublesome. We then upgraded the thickness of the the 3 main power wires (more of an add on, less of a replacement) and when we hooked everything up there was no crank and many different fault codes on my dash. The anti-theft light also comes on as a solid light and then turns off after about a minute. When turning the key to the crank position the dash lights just shut off (could be considered dimming) and then they turn back of right after.
Any help will be greatly appreciated. Thank you so much!
Oct 30, 2019 at 10:59 AM (Merged)
AUSTIN5432W33
  • 7 POSTS
Check all your grounds and make sure everything is connected correctly and that no fuses are blown. If everything is connected correct and still no crank try tapping the starter with a screwdriver while someone else tries to crank. If it does replace starter. Send me some pictures if you want and I'll see if I can help more
SANTIABEYTA1266
  • 15 POSTS
First thing in the morning I will send pictures.
  • 55,748 POSTS
If I can jump in here. it sounds like the battery is weak. To be sure lets run down this guide to confirm the failure:
SANTIABEYTA1266
  • 15 POSTS
Okay, after getting a brand new battery, still no crank no start.
Nov 1, 2019 at 5:48 AM
  • 110,248 POSTS
Welcome back:
If the battery is good, I need you to confirm there are no loose or corroded terminals on or from the battery. When you say the lights dim or go out, that is either a weak battery as Ken mentioned, a loose or corroded connection, the starter is bad, or the engine is locked and the starter can't turn it.
What I need you to do is check if there is power to the starter. On the starter you will have a large wire straight from the battery positive. Is should have 12v all the time. There will also be a smaller wire which only gets power when the key is in the start position. I need you to confirm that is what is happening. If it is getting power, remove the starter and have it bench tested. Most parts stores will do it for free with hopes of selling a new starter. If it passes the bench test, see if you can turn the engine at the crankshaft using a socket and breaker bar to confirm it can turn.
Here is the link I was referring to. Take a look through it and let me know if it helps or if you have other questions.
I need to know one more thing. You replaced the battery, so it should be good. When you said the lights go out, does everything electrical stop for a short time and then start working again? If so, take a look through this link:
Let us know what you find.
Nov 2, 2019 at 4:29 PM
SANTIABEYTA1266
  • 15 POSTS
I can answer a few of these questions now.
1. Brand new battery terminals but they are possibly just aren't that good (already ordered some nice ones) there is also no corrosion anywhere.
2. The electronics only dim out for maybe half a second and then come back to full brightness. I do hear a click but it does not come from the starter. maybe a relay click of sorts?
3. The starter makes no clunk or any types of noises.
I should be able to test the starter tomorrow morning so we will see how that goes and I will update you then.
Thank you so much for your efforts to help me out!
Nov 2, 2019 at 5:52 PM
  • 110,248 POSTS
Welcome back:
You mentioned that the lights only dim for a second. Do they return to normal only after you release the key from the start position or can you hold it in the start position and they still return to normal?
Also, I attached a portion of the starting system schematic. I circled thing I need you to check.
Nov 3, 2019 at 9:13 AM
SANTIABEYTA1266
  • 15 POSTS
There is a constant power to the starter but no power to the smaller terminal when turning the key.
Nov 3, 2019 at 9:14 AM
  • 110,248 POSTS
Welcome back:
We now need to back track. Have you checked the fuses and relays I mentioned?
Nov 3, 2019 at 9:30 AM
SANTIABEYTA1266
  • 15 POSTS
How do you check a relay?
Nov 3, 2019 at 3:11 PM
  • 110,248 POSTS
If there is another relay in the box with the same part number, switch them. Or, here is a link that shows how it's done:
Hope this helps. Let me know.
Nov 5, 2019 at 2:46 AM
SANTIABEYTA1266
  • 15 POSTS
Okay, I am so sorry I took so long. The relays seem to be good. I switched them out and still nothing. Also a correction to the lights thing, the lights turn completely off for like a second and go back on instantly after. I also really don't know how to check the neutral safety switch.
Nov 19, 2019 at 2:09 PM
  • 110,248 POSTS
No problem on the delay. If the lights go out and then come back on, it isn't the safety switch. Something is causing a power loss. Most commonly a bad ground at the engine or at the battery. Are you certain the starter isn't getting power via the smaller wire connected to the S terminal on the starter? It will only get power when the key is in the start position.
Nov 20, 2019 at 6:47 AM
