No power to the truck when key turns the ignition?
243,000 MILES • 3.6L • V6 • 2WD • AUTOMATIC
STACI TITTLE
I know, my boyfriend connected something in my ignition, more along the lines of of my ignition, I think I put in the key I turn it, but there’s no power at all whatsoever. I know he disconnected something because he was messing with underneath the dash.
Feb 4, 2023 at 2:30 PM
  • 55,512 POSTS
I would start by checking the battery cables.
This guide can help you see what I am talking about:
Also, we should check the fuses. This guide can help with the fuse location in the images below:
Next can you upload a picture of the work that was done? Here are the wiring diagrams of the ignition switch so you can reconnect the wiring, I am not sure of what you need so an image will help. Check out the images (below). Please let us know what happens.
Feb 5, 2023 at 3:42 AM
