Seems like electrical problem somewhere under dash near where left foot is, started hearing a buzzing/clicking sound and noticed the battery needle was fluctuating up and down, checked battery and found battery had dead cell and wouldn't charge. Replaced battery, and tried to start, it cranked over a few time and then went dead. Thought it might be the starter, sink took it out and I'm going to take it to have it checked, while I was under truck I took my voltage meter and check the power wires to starter, I got 12 volts on the red heavy wire and then had wife turn the key as if she was starting it while I checked for voltage on the solenoid wire. I did not get any thing on the small solenoid wire. Other people I have talked to said to check the starter relay, problem is, is I don't know where that's located, would that possibly be the noise i was hearing under the dash, if more info is needed please feel free to ask. I will let you know what the auto store says about the starter later today
Dec 18, 2015 at 11:49 PM
