No power to some fuse terminals (driver side under hood fuse box)
47,000 MILES • 2.5L • 6 CYL • 2WD • AUTOMATIC
JOHN LE
Hi, long story short, my driver side low beam stopped working suddenly. I have replaced bulbs, no help. I have replaced ballast, still nothing. Checked all fuses at all three boxes, may were blown (no idea how it happened).
I then used a fuse lamp to check everything else, there are no power to some of the terminals in the middle row of the driver side under hood fuse box. Any chance you guys can help me? Low beam head light on driver side is the only thing that isn’t working. so that’s strange.
May 12, 2019 at 2:42 PM
SCGRANTURISMO
  • 4,897 POSTS
Did you need all three fuse boxes or one in particular? I have a treasure trove of information on all three fuse boxes, but it is extensive and will take a while to copy and send, so if you could be more specific that would be very helpful, unless you need all of it.
Thanks,
Alex
2CarPros
May 12, 2019 at 4:24 PM
