No power to right rear door
280,000 MILES • 5.3L • V8 • 2WD • AUTOMATIC
APRIL OLSON
Right rear door will not lock or unlock and window does not go up or down from any of the switches. The rear hatch will not lock with any of the switches but the rear hatch switch will still lock and unlock everything except itself and right rear door. When I shut my vehicle off, normally the radio will continue to play until one of the doors are opened. But the right rear door does not shut the radio off like it has lost all communication to the vehicle. The rear hatch door will shut the radio off.
Feb 25, 2018 at 4:31 AM
  • 31,937 POSTS
Look for a broken wire or wires in the loom between the door and the pillar, you often get a break here inside the plastic outer sleeve.
Feb 26, 2018 at 6:45 PM
APRIL OLSON
Ok, I was going to try that but I believe the door and rear hatch don't have a common wire so thought that wouldn't be the problem.
Feb 27, 2018 at 11:02 AM
  • 31,937 POSTS
You may need to check both, broken wires are very common on doors and lift gates etc.
Feb 27, 2018 at 5:32 PM
APRIL OLSON
Thank you. May be a couple days until we can tear into it. Weather is horrible but wish me luck!
Feb 27, 2018 at 7:51 PM
  • 31,937 POSTS
Ok, but don’t expect to see a wire broken in half, often the insulation is still ok and the internal wire has fractured, gently pull
On wires to look for unusual stretch, this is a good sign that the wire has fractured
Feb 28, 2018 at 3:41 AM
