Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Cadillac
Eldorado
Electrical
Main Power Relay
No power to relay
1999 CADILLAC ELDORADO
140,000 MILES • V8 • 2WD • AUTOMATIC
BILLY PRELIPP
MEMBER
1 POST
Fuel pump is working but not getting power to fuel relay or fuel pump fuse. What could it be?
Dec 9, 2018 at 5:43 AM
Experienced Mechanic
Good evening,
If you have no power to the fuse then there is a problem with the fuse block itself. Without that power, the pump will never work.
I attached a wire diagram for you to view.
Image (Click to enlarge)
Dec 9, 2018 at 5:54 AM
Add image or video
Ask a new question
Engine won't start
Engine overheating
