No power to obd2
220,000 MILES • 3.8L • 6 CYL • FWD • AUTOMATIC
TINA JOSH WATTS
Not enough power to obd2 connector to connect to scanner. test light just blinks. i have checked all sensors and fuses. try to reset security. what could i try next? i replaced heater coil about a month this is a issue sense then..
Aug 28, 2017 at 5:35 PM
STEVE W.
  • 15,410 POSTS
Sounds like a pinched wire or a bad connection. The ALDL gets power from the ALDL/onstar fuse. If the power feed to the Onstar module was damaged or pinched it to a different wire it could cause problems.
Aug 29, 2017 at 4:08 PM
