Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Honda
Passport
Engine
Computer
Diagnostic Connector ALDL
no power to OBD port
1996 HONDA PASSPORT
188,000 MILES • 3.2L • 6 CYL • 4WD • AUTOMATIC
SHANER64
MEMBER
1 POST
what fuse do I check? Thank you.
Sep 1, 2021 at 3:02 AM
STEVE W.
Experienced Mechanic
That would be fuse EB2 in the fuse and relay box under the hood. This will give you a way to test the fuse with a test light.
Image (Click to enlarge)
Sep 1, 2021 at 12:43 PM
SQM
It should be the horn fuse that power the diagnostics port.
That fuse located in the fuse box under the hood on the passenger side. See diagram below.
Let me know of any questions.
Images (Click to enlarge)
Sep 1, 2021 at 12:49 PM
Add image or video
Ask a new question
Engine won't start
Engine overheating
