No power to low pressure switch?
100,000 MILES • 5.3L • V8 • 2WD • AUTOMATIC
ROY JR MARTINEZ
All fuses and relays good. Controls all light up, three wires at pressure switch. Checked each with a test light none lit it up.
Apr 29, 2023 at 11:14 AM
  • 55,694 POSTS
There is no 12-volt power that goes to the A/C pressure switch, there is a 5-volt reference, a pressure signal and a low sensor reference. Here are the wiring diagrams for the pressure sensor so you can see for yourself. Check out the images (below). What kind of problem are you having?
Apr 30, 2023 at 4:01 AM
