No power to fuel pump?
112,000 MILES • 5.0L • V8 • 2WD • AUTOMATIC
85CV
There is no power to the fuel pump relay, in or out.
Aug 12, 2022 at 6:06 AM
  • 55,694 POSTS
There is no fuel pump relay for this car? It is mechanical.
Aug 12, 2022 at 9:08 AM
85CV
Thank you for the information, but this 1985 Ford LTD Crown Victoria has an in-tank electric fuel pump. Some models did have mechanical fuel pumps, but this one has an in-tank electric pump. Sorry. Any suggestions on how to check if there is no power to the fuel pump relay? Thank you.
Aug 13, 2022 at 2:37 AM
  • 55,694 POSTS
Thank you. I looked for 1986 engine control and found it, there is an 18-gauge fusible link that goes bad near the starter solenoid, pull on each of them to see if one is rubbery. Here are the engine control and fuel pump wiring diagrams so you can see how the system works. Check out the diagrams (below). Please let us know what you find.
Aug 13, 2022 at 5:39 AM
85CV
Thank you, I'll give this a try.
Aug 13, 2022 at 7:30 AM
  • 55,694 POSTS
Aug 15, 2022 at 4:29 AM
85CV
The problem turned out to be with the car's computer unfortunately. We used a fusible link to provide power to the fuel pump relay to bypass the issue at this point so the car runs. Thank you for your help.
Aug 25, 2022 at 6:10 AM
  • 55,694 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Aug 25, 2022 at 10:22 AM
