Shut off while driving there is no power to the fuel pump?
137,981 MILES • 4.0L • 4 CYL • 2WD • AUTOMATIC
WM JENKINS
I was driving home, and it just quit running like you turned the key off. I have been doing some trouble shooting myself and found out that I'm not getting power to the fuel pump. jumped it with a hot wire and it came on. Any suggestions for what to do now?
Dec 20, 2023 at 4:24 AM
  • 55,561 POSTS
When you jumped the fuel pump did the engine start? There are many things that can make the fuel pump relay not turn on like a bad MAF, crankshaft angle sensor, bad PCM, let's run the codes to see what is stored in the computer. This guide can help:
We should check the fuses as well, Sensor1 and IGN Coil fuse in the main fuse panel under the hood, this guide can help:
Also, this guide is a general guide on what can make as engine stop running:
https://www.2carpros.com/articles/car-not-running-advanced
Check out the images (below). Let us know what you find.
Dec 21, 2023 at 8:53 AM
