no power to coil pack
120,000 MILES • 3.4L • 6 CYL • 2WD
BEVERLY MAYNARD
  • 31 POSTS
no power coil pack drivers side.
Jun 8, 2017 at 3:49 AM
HMAC300
  • 48,601 POSTS
scan for codes and check all fuses under hood. check connections on coils as well. start there.
Jun 8, 2017 at 5:18 AM
BEVERLY MAYNARD
  • 31 POSTS
I checked all fuses all good all good one of my starter relay has only power on one side here is one for you if you use dexcool in your chevy get it out it out it will eat you gaskets trust me [BENJAMIN ]
Jun 12, 2017 at 7:37 AM
HMAC300
  • 48,601 POSTS
then it's a fuse box problem if no power check your larger fuses under hood and what you say about dex cool is not true
Jun 12, 2017 at 8:19 AM
