No power to clutch safety switch
90,000 MILES • 4.0L • 4 CYL • 2WD • MANUAL
TEDDYBLAIR
No power to clutch safety switch so it won't start. It will start if pushed to start. Can't figure out what's wrong already replaced the clutch safety switch.
May 1, 2016 at 2:41 AM
CJ MEDEVAC
  • 11,000 POSTS
NOT SEEIN' A 4.0 LITER? (2.2 or 3.1)
RS or Z24?
CONVERTIBLE OR COUPE?
THE MEDIC
May 1, 2016 at 2:51 AM
TEDDYBLAIR
Sorry it is 3.1
RS
Coupe
May 1, 2016 at 2:56 AM
CJ MEDEVAC
  • 11,000 POSTS
GREAT!
BACK SOON!
THE MEDIC
May 1, 2016 at 2:58 AM
CJ MEDEVAC
  • 11,000 POSTS
GRABBED A DIAGRAM FROM "PRODEMAND"
IN ORDER TO GET IT I HAD TO MAKE 2 SCREENSHOTS (WE HAVE PERMISSION)
THE 1st IS THE UPPER HALF, THE 2nd IS THE LOWER HALF (WHICH OVERLAPS THE UPPER)
"AT" IS AUTOMATIC TRANNY
"MT" IS MANUAL TRANSMISSION (AS FAR AS FOLLOWING THE DIAGRAM)
AT THE TOP, THE IGNITION SWITCH SHOWS 2 "HOT" FEEDS, DO YOU HAVE 12 VOLTS ON EACH?
THE YELLOW WIRE TO THE CLUTCH SWITCH SHOULD BE HOT
IF NO JUICE IS THERE, IT'S A PROBLEM FROM ABOVE IT
HOW ARE YOU TESTING THIS?
IF YOU HAVE A 12 V TEST LIGHT, YOU NEED A GOOD GROUND FOR THE LIGHT
SAME GOES FOR A VOLTMETER!
YOUR TURN
THE MEDIC
(MY PICS ARE SORTA GENERIC CHECKING STUFF ON MY JEEP)
May 1, 2016 at 3:33 AM
