No power to climatronic
188,000 MILES • 2.8L • 6 CYL • 2WD • AUTOMATIC
RYANLEAF
#5 fuse keeps blowing. What is causing it to blow?
Sep 28, 2019 at 10:28 PM
Looks like the Climatronic module and the AC pressure switch are on this fuse. If you have not replace this, I would suggest trying that first. More than likely this is shorted. Unless you have a wire that is shorted this switch is the most likely cause. A fuse blows because there is too much current on the circuit. This normally happens due to a shorted component so I would replace the switch and go from there.
Sep 30, 2019 at 10:15 AM
