I've tested the wiring harness up to the plug where it plugs into the bottom for the fuse box, but when i plug it in i get two dead fuses that won't get power, but all the other ones do.
The two fuses are for starting and running the car.
I can use a wire from that fuse to the battery and the car will start but then i won't get any throttle body with the gas pedal.
Mar 7, 2022 at 11:07 PM
