Power steering not working
2006 NISSAN MURANO
165,000 MILES • 3.1L • V6 • 2WD • AUTOMATIC
EDNA VICKREY
I've replaced the power steering pump, belt, pulley, and rack. I still don't have power steering. It's easier to steer the faster I drive. The air has been removed from the fluid with a pump I borrowed from the parts place.
When the pulley was installed, it was installed backwards causing the new belt to be ruined. A new pully and belt was installed correctly after that.
I don't have any power steering at all. Please help.
Dec 29, 2021 at 10:38 AM
  • 110,244 POSTS
With the engine running, can you see the power steering fluid flowing in the pump? Also, when you reinstalled the pulley, are you sure it is turning the shaft, or could it be slipping?
Take a look through this link and let me know.
https://www.2carpros.com/articles/remove-reinstall-power-steering-pulley
Dec 30, 2021 at 10:08 AM
EDNA VICKREY
I'm trying to get somebody to come and check that fluid I'd moving.
Jan 1, 2022 at 3:51 AM
  • 110,244 POSTS
Okay, let me know what you find or if there is anything I can do to help.
Take care and Happy New Year.
Jan 1, 2022 at 1:44 PM
