Did you disconnect it from the ECM? The ECM may be grounding the wire. Other wire is open between the tap and the relay.
Saturday, May 19th, 2018 AT 4:05 PM
REBELROUSERD
MEMBER
I inserted the wire into the plug and plugged it back on the ECU then connected the test light to the wire. This truck runs I just wanted to do this test to see if it would tell me I was getting power there so I could go to the truck that is not getting power to pin 85 and see if I was getting it from the ECU.
SPONSORED LINKS
Saturday, May 19th, 2018 AT 4:17 PM
MECHANIC
Okay, it sounds like the wire between the ECM and the relay is the issue. We discussed this way back in our posts.
Saturday, May 19th, 2018 AT 4:23 PM
REBELROUSERD
MEMBER
Yes on the truck that is not running. This is on a running truck. I wanted to see if it would light my test light before I went to do the same test on the truck that is not running but if it does not light up on a running truck. I am not sure how I will know if I am getting power at the ECU on the non running truck.
Saturday, May 19th, 2018 AT 4:34 PM
MECHANIC
You are most likely testing a ground. That is why there is no voltage. A ground circuit has 0 volts.
SPONSORED LINKS
Saturday, May 19th, 2018 AT 4:38 PM
REBELROUSERD
MEMBER
I have the wire inserted in to the plug that has the green/white wire that goes to relay pin 85.
Saturday, May 19th, 2018 AT 4:45 PM
MECHANIC
The ECM is the ground side of the control side of the relay.
You need to check the wire from the ECM to the relay.
Saturday, May 19th, 2018 AT 4:48 PM
REBELROUSERD
MEMBER
According to the schematic the green/wire runs from this plug to to pin 85 on the relay. So I do not understand how it could be ground if it supplies power to pin 85. Would you not have to have power coming from the ECU to power pin 85? If so when I know this truck runs would I not have power on the this wire. The link below is the schematic I used and my test wire is in pin 1PCM black plug. http://troubleshootmyvehicle.com/gm/4.3L-5.0L-5.7L/pcm-connector-pin-outs-1996-1997-page-4
