no power on light switch headlights still do not work?
140,000 MILES • 2.8L • 6 CYL • 4WD • AUTOMATIC
KOEN LAURIJS
We are restoring the car listed above. We renewed the light switch but the headlights still don't work. Seems there is no power going to the light switch. If we short circuit power to the light switch the light work and the interior lights and power locks as well. The fuses are okay. So far we are not able to find were the power failure is caused by.
Sep 16, 2025 at 9:26 PM
  • 55,694 POSTS
So there is a circuit breaker that run the headlights:
Located Behind Instrument Panel, Near LH Side Of Glove Box.
If you cant find it I would run a 40 amp fuse to the main power lug of the switch, (red) the orange wire is the power input for the running lights. This should fix it. Please let us know what happens.
Sep 17, 2025 at 2:41 AM
KOEN LAURIJS
we could not find the circuit breaker so we used the second suggestion and the lights work :) TX
Sep 26, 2025 at 9:06 PM
  • 55,694 POSTS
Good to hear, please use 2CarPros anytime we are here to help. Can you please leave us a rating?
https://g.page/r/CZdEnyCkGgm6EB0/review
and
https://www.sitejabber.com/reviews/2carpros.com
Thank you!
Sep 27, 2025 at 4:10 AM
KOEN LAURIJS
Hy Ken, Sorry to bother you again but are problem appears to be not completely solved. When the headlights are turned on for several minutes they start pulsating. You can hear it click in the light switch. Apparently there is to much current and it gets to hot. Wat can we do now ??
Dec 14, 2025 at 4:17 AM
  • 55,694 POSTS
Heat will be causes by a bad connection in the switch or at the headlights themselves. I would check the headlight electrical connectors for corrosion/melted. if they look okay I would replace the headlight switch. Please let me know how it goes.
Dec 15, 2025 at 3:50 AM
