no power on coil and fuel pump
1999 DODGE DURANGO
150,000 MILES • 5.9L • V8 • 4WD • AUTOMATIC
JNESIS247
am working on a 99 dodge durango 5.9l, it has a no spark, no start issue, i ve tested to see that there is no power to the coil and fuel pump, yes i have12v power going to the crank sensor..have replace the crank position sensor,swap the asd relay,replace plug wires but the problem persist.
Today ,i noticed some burnt wires on top of the transmission by the passenger side,i see that these wires goes into the two sensors on the exhaust manifold.could this be the problem?please i need some help.possibly some wiring diagrams.thanks.Nnamdi Ab
Jan 1, 2014 at 3:49 AM
HMAC300
  • 48,601 POSTS
hard telling if it's the problem bu ti can't be good and proably cold cause the problem i'm sending diagram of O2 sensors, cant send whole schematic to big.check cam position sensor as well though. also unplug O2 sensor and see if it starts that would tell you it may have torched the puter too. there is a couple of these on tips that have done this.
Jan 1, 2014 at 4:24 AM
MAXIMILIAM
  • 436 POSTS
Please i have this desire to upgrade my auto technical know how, can you recommend any online school for me?
Thanks!
Nnamdi
Jan 6, 2014 at 8:33 PM
HMAC300
  • 48,601 POSTS
no I cant look online for them
Jan 6, 2014 at 9:52 PM
