No power, misfires, rough idle and code p0300
150,000 MILES • 2.2L • 4 CYL • 2WD • MANUAL
MSTA4D
Started car and it was running rough, took off and sounded like it was misfiring. when I give it gas it's like it doesn't want to take it for a few seconds then does, when going up a hill it wont take fuel like the fuel filter is clogged, rpms go all the way down even if pedal is pushed down then will slightly take gas and have to let off pedal because rpm's shoot up. it is jerking when trying to give gas like your trying to take off in to high gear, error code p0300.
Oct 10, 2020 at 10:49 AM
  • 110,248 POSTS
The code is a random misfire. It could be several things causing it. Lets start simple. First, check to make sure there are no engine vacuum leaks. Here is a link that shows how it's done:
Check to make sure none of the vacuum hoses are disconnected, cracked, or broken.
Also, take a look through this link and let me know if it helps.
Let me know if that is the only code you have and if anything sounds differently.
Oct 10, 2020 at 10:55 AM
With a multi cylinder misfire we need to start with things that can effect the entire engine. Basically what this code is saying is one cylinder misfires then it does not and then it starts again and that multiple cylinders are doing this. So there is no one consistent misfire. That means it is normally air or fuel. Let's start with these two guides to try and figure out if you have a vacuum leak or fuel pressure issue.
Let me know what the pressure is and then we can go from there and if you find no vacuum leak then we can move on but I suspect based on what is happening that we will have an issue with one of these. Thanks
Oct 10, 2020 at 10:59 AM
