No power locks with button, switch or key
243,427 MILES • 5.7L • V8 • AWD • AUTOMATIC
JESSICA SMITH-WAGNER
The power locks on my truck suddenly quit. The windows are fine but locks on all 4 doors only work manually. Usually locks engage when truck is put in drive & unlock when put in park&engine is shut off. This doesn't happen & only the driver door locks from the outside using the key when all 4 doors are supposed to lock. I'd appreciate any ideas you could throw my way as to what the problem could be! Thank you!
May 1, 2016 at 12:07 AM
HMAC300
  • 48,601 POSTS
check items in pic then take remote to auto parts and see if remote is working or battery dead they can check it. finally have it scanned for codes it may be a module problem . a mechanic will have to do that
May 1, 2016 at 1:21 AM
