No power, just clicks when attempting to start it?
980,000 MILES • 5.0L • V8 • 2WD • AUTOMATIC
BILL CHANTZOPOULOS
When I try to start the car when I get to the crank, nothing happens. So, I thought that I needed an alternator, so I changed it and it did not help. Still no crank no start.
Jul 17, 2022 at 5:29 AM
STEVE W.
  • 15,415 POSTS
No start but a click is usually battery related, either it has low voltage, or the connections are corroded, or both. As you can see from the diagram there are only a few grounds that connect most systems.
Try reading this guide about this similar issue:
Jul 17, 2022 at 7:56 AM
