My surf runs doesnt give power on hills,Engines dies out, The turbo doesnt kick in,
drives in hills at 20 kmph.
Aug 10, 2015 at 10:15 AM
HMAC300
✓Experienced Mechanic
scan for codes and check fuel pressure with a gauge auto parts rent it.
Aug 10, 2015 at 11:29 PM
SHEGRAN
MEMBER
It was giving two codes 11- ECU(+B) and 12- RPM signal (Cranking).
I have tried adjusting pump. But it doesnt help.
At times turbo kicks in and after some time rpm suddenly drops.
Aug 11, 2015 at 7:26 AM
HMAC300
check dist wiring for a short between dist and ecu also check for wire leading to ecu from positive for same. check all fuses with a test light as well auto parts rent gauge but yo may need an adapter 33-37 psi regulated and 38-44 unregulated.
Aug 11, 2015 at 9:44 AM
SHEGRAN
MEMBER
thanks Hmac,
I have check all the fuses but im left with the shorts,Will update you asap.
