No power going to fuel pump
1989 GMC S15
4.3L • 6 CYL • 4WD • AUTOMATIC
ALDERSONK
There is no power going to fuel pump. The truck runs if you spray starter fluid in throttle body. There was a broken wire behind the engine I fixed, new fuel pump tested before installing, also new fuel pump relays and fuses. Have looked everywhere on truck I cant figure it out. Was driving it was running good and just stopped fueling.
Jun 6, 2014 at 1:26 PM
  • 110,241 POSTS
Have you checked fuses? Is there power at the fuel pump relay?
Jun 6, 2014 at 1:47 PM
WRENCHTECH
  • 20,761 POSTS
Are you sure you are testing it correctly? It only powers for 2 seconds when the key is first turned on. Power resumes when the computer sees a tach signal from the engine cranking.
Jun 6, 2014 at 7:33 PM
ALDERSONK
I've checked the fuses they are fine. there is no power going to the fuel pump. I have ohm checked the wires from the relay to the pump there is normal resistance (0.7ohms). there is power to the relays.
Jun 7, 2014 at 1:58 PM
