No power fully charged battery
155,157 MILES
JOSHUA A VAN HOY
Had battery replaced it started just fine, sat for three days went put key in ignition turned it and nothing no power whatsoever. checked connection to battery seems fine battery charged now steering is locked and key stuck in ignition.
Jul 19, 2019 at 9:31 AM
SCGRANTURISMO
  • 4,897 POSTS
Can you take a voltage reading with a multi-meter across the battery terminals for us? Here is a link for you to go to below, if you are unfamiliar with how to use a multi-meter, if needed:
Please go through this guide and get back to us with what you are able to find out.
Thanks,
Alex
2CarPros
Jul 19, 2019 at 1:02 PM
