no power from the battery?
148,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
EPIP
car wouldn't start at work, tow home , so thought fuel pump replaced , fuel filter replaced , timing belt cracks in it replace , started it and started getting miss fires , and check engine light flashing , so replace coil and spark plugs , car starts so had to move it about 30 feet , ran rough but moved , now trying to start I get no power nothing , charged battery overnight still nothing. can you help? thanks for any help, Tim
Jun 17, 2025 at 11:51 AM
  • 55,746 POSTS
So it sounds like the battery went bad, you have no light at all, no headlights? If so, this can be the problem. Can you upload a short video of the problem so I can see what's going on? You may have a blown head gasket, and one cylinder is full of coolant not allowing the engine to crank over. Please go over this video which can help as well:
https://www.youtube.com/watch?v=6YRW8fyNudY
Please upload a video in your response :)
Jun 18, 2025 at 12:10 PM
