When replacing the distributor cap and ICM under the cap I forgot to disconnect the battery cables, now there is no power/electric?
113,000 MILES • 4.3L • 6 CYL • 2WD • AUTOMATIC
CHRISINOHIO
While changing the distributor cap and ICM under the cap I had forgotten to unhook the battery cables. I heard a shorting out noise from somewhere. I purchased and installed another new ICM and now I have no power anywhere even with a jump start. I haven't been able to find a fusible link so far, but am at a loss and any help will be much appreciated.
Oct 2, 2022 at 1:57 AM
  • 55,725 POSTS
The fusible links are:
Left hand front of firewall, near bulkhead connector.
Oct 3, 2022 at 4:07 AM
CHRISINOHIO
Thank you. I will look into it after work and leave a comment! Thanks for your time!
Oct 3, 2022 at 4:40 AM
  • 55,725 POSTS
No problem, let me know what happens please.
Oct 4, 2022 at 5:44 AM
