Intermittent no power at start?
87,000 MILES • 4.0L • 6 CYL • 2WD • AUTOMATIC
DONNIE J EDWARDS JR
Accessory key position all function properly. Turn the key to start, all power gone and goes black. Have to disconnect/reconnect the battery to correct and then she starts fine. Only happens intermittently.
Sep 24, 2022 at 9:37 AM
  • 110,248 POSTS
What you described sounds like a connection issue. Does this happen every time you try starting the vehicle?
Do me a favor. Take a look at this link. It discusses what you described and how to fix it. Let me know if it helps.
Sep 24, 2022 at 4:23 PM
DONNIE J EDWARDS JR
Your assistance corrected the problem. The negative side of the battery terminal was loose. So far everything seems to be working fine. Thank you.
Sep 26, 2022 at 4:44 AM
