No power at all?
120,000 MILES • 4.0L • V8 • 4WD • AUTOMATIC
YOITSTJ
This is the Eddie Bauer Edition Explorer. Both turning signals had quit working and I was told that if the flasher was working then it was probably a bad switch. So, the next time I got in the vehicle I turned on the flashers and they flashed a couple of times and then everything went out. Now no power to anything at all. Won't start nothing. What could have happened to cause this?
Jul 31, 2025 at 3:22 PM
  • 55,732 POSTS
This can be a bad battery or a bad connection at the battery. I would remove the battery and take it to the auto part store for testing. Here is a guide to help you if it is a bad connection at the cables.
Please upload pictures or videos in your response of any problems, that way I can see what is going on.
Aug 1, 2025 at 5:47 AM
