No power at all, no crank, no clicks?
110,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
TOOGOOD80
Car was driving fine, had the code of immobilizer pop up every now and then had water on passenger floor the BCM or CEM shorted out. replaced the old BCM cem with a new one from same make and model. no power at all, no headlights, no crank, no clicks, and no dash lights. I replaced the ground wire that was melted. What could be the problem? Could it be relays? I checked out fuses and fuses are good and don't see any more burnt up or melted wires.
Feb 22, 2025 at 2:18 AM
CANNON1349
  • 861 POSTS
Hello, if this is a new, fresh CEM (Central Electronic Module) then the module will have to be programmed. If you do not have the software to program it, then you may have to tow the car to the dealer for programming. I will give the instructions for replacing the CEM for others to read as well. There are some companies like ECU Maverick or Flagship One that sell pre-programmed modules. I would check them out!
Remove:
- the 2 clips
- the soundproofing panel. Pull straight down, then backwards.
(See image 1)
Removing the central electronic module (CEM) / relay box
Remove:
- the 2 screws
- the control module / relay box. Fold down and pull towards you.
(See image 2)
NOTE: Ensure that the control module / relay box is in the lower position when you remove it from the mounting.
- the cable ties
- the connectors.
NOTE: Note the location of the relays.
Remove relays and fuses from the control module / relay box.
HINT: For the location of the relays and fuses, see:
- Wiring diagrams for relevant model year.
- Decals at both the relay box and the fuse box in the car
- Pocket Data Booklet
- Owner's Manual.
Installation
Installing the central electronic module (CEM) / central relay module
CAUTION: The pins are fragile. Check that the connector goes straight down into the control module.
Install:
- relays. Take care with the positioning
- the connectors. Press down carefully
- the 2 screws
Install the soundproofing panel, 2 clips.
Install the battery negative cable.
Ordering software
Order software. See:
S40 (04-) 30667203
V50 30667204
C70 (06-) 30765934
C30 30765935
Finishing
Programming control module
NOTE: Applies to 2005-. Program the mode global opening/closing was programmed in. See Vehicle communication, Programming global opening/closing window.
Reset the service indication message. Otherwise, the lamp receives the incorrect reference. Global time is reset when replacing the Central Electronic Module (CEM). Resetting of the service indication message is carried out according to resetting the service indication message.
Feb 22, 2025 at 5:56 AM
