There is no power coming from my inner fuse box
100,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
DAVE BURKE
I turn the key and motor turns over but no power to anything inside the car. What could it be?
Dec 20, 2019 at 12:20 PM
  • 110,248 POSTS
There are two fuses under the hood of the vehicle (power distribution box) which supply power to the instrument panel fuse box. I attached a pic below of their locations. Check both of them.
Here are a few links you may find helpful:
If you find a bad fuse, only replace it with the same type and amperage.
Let me know what you find.
Dec 21, 2019 at 3:45 PM
