While driving engine will not go above 3,000 RPMs?
211,852 MILES • 5.7L • V8 • 2WD • AUTOMATIC
THEDOOMSLAYER21
My pickup started not going above 3,000 rpms when driving, this happen shortly after I was driving about 200 miles usually I stay in town, and popped up a check engine light… 3 days later check engine light is gone, but now I can’t go above 3,000 rpms, and if I try and WOT the engine back fires, but for some odd reason the engine will easily rev up to 5,000 rpms in park but not in neutral, transmission shifts smooth and engine runs smooth just as long as it’s under 3000 rpm! Pickup is a c1500 5.7 vortec.
May 27, 2023 at 1:44 PM
AL514
  • 5,699 POSTS
Hello, it sounds like the truck might be in reduced power mode. What codes are stored in the ECM?
These trucks have the poppet style fuel injectors with a central injector assembly, sometimes they are called a spider injection system. They are known for failures and there is actually an updated design I have seen. So, if the code has anything to do with fuel control faults this system may be to blame but let us know what codes are stored first.
May 29, 2023 at 5:37 AM
