no power
85,000 MILES • 1.1L • 4 CYL • 2WD • AUTOMATIC
HERMES1
high rpm
Jan 11, 2020 at 2:35 PM
SCGRANTURISMO
  • 4,897 POSTS
When your vehicle's engine has a high RPM's it is usually due to a vacuum or intake leak. An intake leak is defined as letting unmetered air into the engine from the Mass Air Flow sensor[MAF} to the engine's combustion chamber. Unmetered air is any airflow that the Power-train Control Module[PCM], or computer, has not accounted for. Here is a link below to a guide that will explain how to find a vacuum leak a little better:
Please go through this guide and get back to us with how everything turns out.
Thanks,
Alex
2CarPros
Jan 12, 2020 at 10:40 PM
