When your vehicle's engine has a high RPM's it is usually due to a vacuum or intake leak. An intake leak is defined as letting unmetered air into the engine from the Mass Air Flow sensor[MAF} to the engine's combustion chamber. Unmetered air is any airflow that the Power-train Control Module[PCM], or computer, has not accounted for. Here is a link below to a guide that will explain how to find a vacuum leak a little better:
Please go through this guide and get back to us with how everything turns out.
Thanks,
Alex
2CarPros
Jan 13, 2020 at 6:40 AM
