Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Dodge
Avenger
Brakes
Pads
Front
I went to turn it on and the brake warning light was on? Brakes?
2011 DODGE AVENGER
97,000 MILES
ZZOBIE1
MEMBER
1 POST
I just replaced my battery three months ago. this morning when I went to turn it on and the brake warning light was on?
Jan 14, 2017 at 4:11 AM
Experienced Mechanic
The brake light remaining on means the brake fluid is low and that is normally due to a leak or the pads are worn and need replaced.
Here is a guide that will help with replacing the pads as that is the most common issue:
https://www.2carpros.com/articles/how-to-replace-front-brake-pads-and-rotors-fwd
https://www.2carpros.com/articles/how-to-replace-rear-brake-pads-and-rotors
Lastly below is the process from the manual that will help with replacing the pads on this vehicle. Let us know if you have other questions. Thanks
Images (Click to enlarge)
Mar 30, 2021 at 7:02 AM
Additionally, here are the installation instructions for the pads and rotors including torque specs.
Let us know if more info is needed.
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
