this car suddenly had a lose of power,slow acelleration ,did full tune up replaced fuel filter and pump.car appears to idle fine but has no power.It also has an exhaust rattle I can't find,maybe inside the cat.Could the cat be bad,partly plugged creating a lot of back pressure?I'm not finding any sign of oil in the water or water in the oil. did compression test have about 120 in each cylinder dry. Also it's not throwing any codes,HELP!!!!
Mar 25, 2017 at 10:06 PM
