No Heater
98,000 MILES
TIMD22
I had to replace the steering coupler and after I got everything back together an made sure everything was connected the climate control, wipers an washer, and fog lights won’t come on and i checked all the fuses an relays to make sure all was good. I traced the problem to the multi function connector for the wipers that hook up to the ignition switch.
Dec 1, 2019 at 11:23 PM
  • 55,588 POSTS
Okay cool, what did you need from us a wiring diagrams or? Please let us know
Dec 2, 2019 at 8:00 AM
TIMD22
Yes I would like one and hopefully a little more insight on the the problem could be. because someone said it could be the ignition switch, but I don’t think it’s that because my car starts and drives fine. I just really need the heat and wipers fixed since it’s getting cold enough for winter where I’m at. I just don’t know why my harness connection isn’t getting power for the multi function switch.
Dec 2, 2019 at 10:34 PM
  • 55,588 POSTS
Can you tell me if the blower motor works? Here is a guide to help us see whats going on with the heater. the wiper issue you will need to start a new question we only handle one problem per thread.
https://www.2carpros.com/articles/car-heater-not-working
Dec 4, 2019 at 4:38 AM
