No power
94,000 MILES
SPORTY66
Went out to leave for work. Car tried starting and now no power at all.
Sep 10, 2020 at 7:55 PM
Good morning,
I would first check the battery. It sounds like low voltage from a discharged battery.
You will need a voltmeter to test the voltage. You need 12.4 to 12.6 volts.
You will also need to check the charging system to be sure the alternator is maintaining the battery charge.
Sep 10, 2020 at 8:29 PM
