Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Lexus
LS 400
Electrical
Electrical Shut Down
no power
1993 LEXUS LS 400
199,999 MILES • V8 • 2WD
ANGELA GREEN2
MEMBER
1 POST
changed the driver headlight, now the car starts but has no electrical nothing, have checked fuses need help asap ty
Sep 24, 2017 at 12:38 AM
STEVE W.
Experienced Mechanic
Did you change the bulb only or the entire assembly?
Did you disconnect the battery?
What does not work?
The description sounds like a connection in the harness was moved and caused a loss of power. The problem is trying to determine where.
Image (Click to enlarge)
Sep 25, 2017 at 11:35 PM
Add image or video
Ask a new question
Engine won't start
Engine has low power
