No power, takes a while to get up to speed
249,000 MILES • V8 • 2WD
TOMMY BOURGEOIS
Car runs great engine revved up in neutral. In drive won’t rev up car barley moves . Throttle only goes up to 1,000 rpm's it takes a while to get up to speed.
May 8, 2020 at 9:19 PM
There are a number of things this could be. Here is a video that runs through the basic causes of this:
Basically you have what is called low power. This is typically caused when the there is a load on the engine like you are seeing.
https://youtu.be/U1RoG3I-Oww
Clearly we need to start checking these things and go from there. Let me know if you have questions when reviewing this material. Thanks
https://www.2carpros.com/articles/symptoms-of-low-engine-power
May 9, 2020 at 10:11 AM
