No power
202,222 MILES • 5.2L • V8 • 2WD • AUTOMATIC
MICHAEL_WAYNE30
I have the truck listed above 1500 with a 318. It was having an alternator problem not charging the battery. well I still didn't solve the problems. I was able to jump that alternator to the battery and it will charge it but my issue is now as I turn my key over and I have no power on the cluster. fuel pumps not kicking on I have no idea what's going on with it. I have a good battery in it it just won't start. it was starting yesterday put a little fuel in the throttle body and it would start and run but I could hear the fuel pump kicking on. now it's not doing anything. I hear the door chiming and that's it. it'll turn over but won't crank. I have checked fuses and seem to be good. I have even changed some of the relays around to the fuel pump one to see if it was good and still nothing.
Sep 3, 2019 at 9:39 AM
  • 55,746 POSTS
It sounds like the battery is weak/bad connection. also I would put the alternator wiring back to the way it was. here is a wiring diagram to help you and a guide:
and
Check out the diagrams (below). Please let us know what you find.
Sep 4, 2019 at 12:13 PM
MICHAEL_WAYNE30
Would that cause my dash lights not to work and my fuel pump not to kick in?
Sep 4, 2019 at 2:12 PM
  • 55,746 POSTS
The ASD relay controls these items. here is a guide to help test the relay and the location as well:
Sep 5, 2019 at 4:35 AM
